Looking for some advice on what gauge mild steel tubing to use for reinforcment of my 914-racecar project.
The rear truck will get an X brace or like, and a bar side to side.
The frt truck where the gas tank was removed will get a brace between the shock tower.
The rear trailing arm ear will get a bar from the trans support to the mount.
And the upper rear shock mount to the firewall will get tied in but not to the cage.
So I was thinking of using a mix of 1.5 1.25 and some .75 16ga steel.
Is that thick enough? See pixs for reference.
P.S. I was wondering if anyone here has tried Tubular control arm reinforcing??? Not as overkill as boxing them. IMHO
