soloracer
Jan 14 2004, 01:48 PM
Anyone done it? If so is it adviseable? How hard/expensive is it to do? I have a 915 sideshift transmission and was curious as to the performance/feel differences between hydraulic and cable clutches.
madd_dogg_914
Jan 14 2004, 01:55 PM
I have seen quite a few threads on this subject. Do a quick search and you will see some nice write ups. If I recall correctly Brad is developing some sort of hydralic clutch package for the 914 (but then again what ISN'T Brad cuurently developing for the 914)
-Chris
L8Apex
Brad Roberts
Jan 14 2004, 02:01 PM
Unless you can weld/fab at home.. it wont be an option for you. It is no easy task.
B
East coaster
Jan 15 2004, 10:07 PM
I checked the links to previous threads in this post and they're very informative. I seem to remember investigating this before and someone mentioning a different pedal cluster which included a clutch return spring. Am I having halucinations or is this something you have to address when you convert to hydro???????
Brad Roberts
Jan 15 2004, 10:09 PM
We just bled another system last night. Stock 914 pedal assembly and a Tilton master/Neal slave setup. It doesnt need a return spring. Works great.
B
East coaster
Jan 15 2004, 10:14 PM
Cool....one less part I need to acquire!! Thanks Brad
Brad Roberts
Jan 15 2004, 10:17 PM
I can show you later how we do it (brackets and all). You should be able to set it up on a 915 for under 400$ (depending on whether or not you weld it all in and fab the brackets).
b
type47
Jan 16 2004, 11:05 AM
VW Vanagon has a hyd. clutch, bet you could use that and fab some parts to apply to 914
stock93
Jan 16 2004, 01:14 PM
Let me know if you guys need some pictures of the vanagon hydraulic setup. I'm probably going to use the one I have on my rail and I doubt you could use it easily on a 914.
John
airsix
Jan 16 2004, 01:22 PM
Hooking the slave cyl. up to the tranny and running the lines in the tunnel are real easy. It's mounting the master cyl. that's a pain. Where you need to mount the MC, the pan is at about a 45 degree angle and you need it to be more verticle. Also, there is very little room behind the suspension crossmember. I like the idea of using tilton pedals beause the master cyl would be in the pedalbox instead of being wedged in that little spot between the pan and the crossmember.
For the record, I love my hydraulic clutch, but it was a lot of work.
-Ben M.
Gary
Jan 16 2004, 03:01 PM
Rich Johnson has one on his machine. I think he has a kit too. It uses a 944 slave. I don't recall what the MC is. His is outfitted on a sideshift 914 tranny. There's a not great picture at:
Rich Johnson's 914Gary
jridder
Jan 16 2004, 04:52 PM
I got a Wilwood clutch and master cylinder. The clutch is a 7/8" and the master cylinder is 3/4". Their largest compact master cylinder is 3/4" so hopefully I can get enough throw with it. The master cylinder has 1.4" of throw which will give me about 1" of throw at the clutch.
If this has no chance of working, let me know. Otherwise, I'll document my installation when I get to it (after finishing the installation of my fuel tank, new fuel lines and fuel injection system on my V8).
Jonathan
L8Apex
Jan 16 2004, 04:59 PM
in order to put a hydro clutch in the car, we need to use a pull type slave cylinder or a pull?
Brad Roberts
Jan 17 2004, 12:12 AM
Rich Johnson sells a kit from Wes Hildreth. The price is 1200$ It uses some stock 928 parts.
The slave has to pull Terrance.
B
L8Apex
Jan 17 2004, 01:15 AM
Brad, thanks. I knew it was a pull, but I was confused when I looked at Rich's site and it said
"This is the push-type slave that actuates the pressure plate / clutch sytem used with the 3.0L flywheel. Note the SS line and the slave cylinder's free-play adjustment system. "
BTW, I'm going six.
Brad Roberts
Jan 17 2004, 01:28 AM
The converted Rich's car to a pull type pressure plate..(I have no idea why)..
B
sechszylinder
Jan 17 2004, 03:26 AM
hi folks,
concerning the master cylinder, i think the 911 87' (g50 transmission) provides a very small one,
which would fit very nicely into our cars.
benno
