For those of you with a car that came with a console
there is a coresponding "taco plate" assemb. at the bottem
of the engine. It is a plate and sender, gasket, then coverplate
with stand to hold the associated green wire with grey sheath.
As the wire is routed over the engine there are at least one (two?)
tabs that pinch and hold that wire until it passes thru the gromet
and connects to the harness.
Does anyone have pics or can explain where the tabs get mounted
Its been so long since I tore it apart that I can remember exactly where they
go.
