Well, after the inside easter egg hunt for my daughter, it was snowing outside, and after we let her play a bit in the snow, I finally did some more work on the car.
I pulled and cleaned up the fuel sending unit; hopefully that is the problem to the gauge doing the whole jumping to full then back to empty deal. Overall the unit was in good condition; also took the time to clean the leads that the cable plugs into.
I also pulled the carbs since I got in the rebuild kits. Talk about a PITA! The left side one wasn't too difficult, tight but not overly challenging. The right side however, was a bit of a pain as the fuel pump is also there and made manuevering a bit challenging. The tin was also bent up a bit and I had to push it down in order to get a socket on the dang nut.
I will have to get a new intake manifold to carb body gasket as they are toast and the kit did not come with a gasket. I am guessing that I will more than likely have to buy some gasket material and make one. I cleaned most of the jets on the right side carb but plan on taking it into the shop on Tuesday to use the solvent tank to finish it up. Pulled all the delicate internals out like the float so I wouldn't lose or damage them.
Overall the carbs are dirty but no major issues mechanically and the floats so far are in good condition and, I believe I solved the mystery tubes. As I read through the Dellorto tech manual I came across this little tidbit of info, "Dual single throat carburetors such as the Dellorto FRD's....run a lot better at slow engine speeds when a balance tube is installed between the manifolds."
Well damn, I bet that is what those tubes are for! So why the hell didn't the PO have them connected? Instead, he had a bolt stuck in the end of each tube! As somone mentioned earlier when I posted the intitial eval and pics, VACUUM LEAK!! Guess I will be fixing that. I think I need new filters though, they are kinda rough. Hope to get them cleaned up and back on the car by the end of this week. Also having a hell of a time finding the right size fuel lines that go between the tank to the main lines. I really miss NAPA parts. Here are a couple of pictures.
