I'm heading to the track in a week and a half and wanted to gather suggestions I can use to make sure my head temps don't run too high. Aside from fuel/spark curve adjustments, what else can I do? I do realize that these two elements are the biggest drivers in the afr/spark curve/head temp combo. But in case I can't dial it in right, I wanted to hear what the alternatives are...
Anything I can do spark plug wise? Run a hotter plug? Change gapping?
Already using 93 octane fuel
Already using 20W50 Brad Penn
I know that to a certain extent additional fueling reduces head temps. I believe I witnessed this, however I'm already running rather rich (12:1). Tomorrow i'm going to try to tune some more.
I figured out a way using the warm up enrichment table to add fuel in case head temps go over a certain value. I was going to add 15-20% fuel if head temp goes over 400F. Is this a bad idea? This might lower AFRs too much, into 10-11:1 range.
I'm monitoring head temps using a dakota digital head temp gauge. Also watching oil temps.
Any thoughts?
