So, I got the carbs done last night, intended to install them today, clean up the gas tank and tank area and start her up tomorrow. Oh while I am at it, I figured I would install the new seat belts I ordered from ebay.
SonofaBI**!! Lets start with the carb install. Started on the passenger side one first since that was the most problematic to remove. Pulled out the battery so I had more space, cleaned up the area and lubed the nuts with some WD40. Pop on the carb, put on the outside nuts and finger tighten them. Then I did the contortionist dance to get the inside washer and nuts on. So far so good.
Start to tighten all nuts incrementally and it is going well...at least until I got to the outside nut closest to the firewall. She starts turning really, really easy. So I pull of the socket and check, whole stud is turning. OK, need to tighten the stud back up...nope the sucker just pulled right out!
Well, that sucker is going to have to be tapped and a new stud inserted, dang it!! OK can't do anything about that so I installed the other side, got everything hooked back up and will have Boxter Motor deal with the stud since I don't have the tools at my house.
So I begin cleaning up the tank and tank area; at least that went OK.
So now lets look at the seatbelt. First issue, the SOBs told me I had to order two of the items as only one belt came in a box. WRONG! I now have two complete sets of belts.
Second issue, they advertised universal fit and specifically 914 fitment. NOT Quite. Will post some pictures of the belt later but needless to say, they won't fit without some modifications.
I had such high hopes for today and they just kinda went to
I need to head into work for a teleconference then I will come back and clean my bike and maybe take a long ride since it is nice today. Some days, I should just stay in bed.
