So I spent most of the day doing basic maintenance, adjusted the valves, bled the brakes, checked a few things.. I'm going to Pocono for a DE event next weekend (april 6-7). In the meantime, I also installed an American International S-25A power line noise filter inline with the 12V signal coming into my relay box (power everything: fuel pump, megasquirt, wideband, etc).
Took it for a ride, felt really good except i was experiencing tach spikes down to 0 and up to 9000rpm. The tach signal would cut out. I checked the data logs, there are no voltage spike issues, just tach. When the spike occurs, I can see the tach actually spike. So I came back, removed the noise filter, went for another drive.. Same problem!! Tach signal drops to zero for a split second. I checked all the connections, made sure the coil is tight, checked the pertonix (gapped properly).
I have no idea what's wrong... At this point i'm pretty frustrated and just want to resolve this pesky issue and have fun next weekend. I might have to take a day off work to get this resolved.
Any suggestions as to what I should look for? Any parts I should order just in case?
When adjusting the valves, I did pop the dizzy cover off. I checked the rotor and all that. It;s not a spark distribution problem, it's a tach pickup problem.
For you megasquirt gurus out there, please help! I attached my log files and .msq file. Thanks!!
Info on my system: Stock frozen dizzy, petronix, vb921 injector driver, low Z injectors (PWM). MS II V. 3.0.
