Easy is well, just too easy! I want to do it the hard way. I just like banging my head against a wall
. Why else would I have purchased my third teener (and of course I had to pick an l-jet!).
I think it would be totally cool to sample and record the inputs and outputs of the ecu in “real-time”. Obviously once you had normal operating parameters identifying in “real-time” component or system level deviations would be a piece of cake. Also, adding new sensors would be totally exciting! For example adding an O2 sensor would enable you to really tune the exhaust gas numbers (closed system)… Tracking ecu data history for component trends would be really interesting in spotting potential component failures. Etc…
I realize that OBDII and current technology provides what I am describing and more. I just want a modern approach to solving the non-digital 914 problem (and knowing when I have solved the problem) of “why my engine is running rich or lean or idles rough”. I want to plug a computer interface into the harness have the computer tell me what component is out of spec (e.g. fault code!) and of course a lot of other cool stuff.
However once you can control the ecu responses based upon ecu inputs. We are know at a another level. Once there, creating driving modes street, track and smog level based upon ecu inputs is totally doable – we could all be sharing digital engine performance profiles.
So has anyone done or is working on anything remotely similar to what I am describing? Is my wife correct… No one cares.
Rodger, thanks for the info I found a lot of new information.
Regards,
James
