For anyone who has followed my engine build this is old news but, for anyone new this is quite a tail. I started getting parts in August of 2004 when I purchased a core engine and tranny from Rich Dauenhauer out of a rusty old parts car. Since then I’ve reassembled this engine 5 times. I started hoping for a good father son experience and the opportunity to learn a little about engines. I got a whole lot more of each than I bargained for.
Before I rehash the whole thing I need to thank Jake, Charles Navarro and Len Hoffman. They stuck by me through the whole experience, even though the contract I signed at the beginning clearly stated any failure was on me. Undoubtedly they have all lost money on my project. Jake even lost a little flesh but that story has been told before. These guys have gone way over the top to try to help me succeed. They set the benchmark for customer service and I can’t recommend them highly enough. Anyway, THANK YOU guys.
So as I said this all started 2004 and Gerry and I spent the rest of the summer and early fall tearing down and cleaning the core parts. We sent the case, crank, flywheel fan, and a bunch of other parts to Jake for checking and machining.
The next spring we got back a bunch of boxes full of parts and they were beautiful. Those of you that have received new parts from these guys know what I mean.
Everything looked too nice to put into an engine.
Gerry and I built the engine with some help from my daughter Sarah.
We went through all of the difficult steps that cause people so much hair pulling like deck height, valve train geometry and end play. All seemed well and we had a light off party with plenty of beer and roasted flesh (fake steak from Costco as Geoff pointed out). I borrowed Kevin’s carbs and we started it with a distributor. Jake was on the phone and Sarah lit it off with a remote starter. No go, the leads for 2 and 4 were reversed (bet there’s been a few guys do that). Jake said it was only hitting on 2 cylinders and Geoff found my mistake. After we corrected it, it ran great and we broke in the cam, then back to the beer.
After it was installed in the car I tried to seat the rings and after a while it became apparent that something was wrong so, out came the engine and we tore it down. The autopsy showed it was very rich, the piston skirts were scuffed and the bores were worn, some of the cam lobes were worn, the main journals on the crank needed polishing, and the inside thrust surface of the rear main was worn.
It took a while but, everything got replaced or refurbished. At that point we blamed the fuel injection and hard starts when it was installed in the car. We felt the oil got diluted. At this point Jake offered to build it and break it in down in Georgia for free but, I hate to quit so I said no.
Back together it went for another try in the fall.
I had even higher oil usage so out it came again and down to the crank. Another flat cam and the same cylinder and piston wear. This time Jake sent a different cam grind on a newer blank. Ramp rates were a little slower lift was a little less and duration was a little longer especially on the exhaust side. Charles sent the P&C set to a fellow in San Diego for a look and they checked out OK so back in they went and back in the engine went. It was better and I ran it for about 6 months. I did a few autocrosses, Gerry did a couple of new driver classes and we drove it to California to meet Jake on his cross country trip in the Blubonic plaque at Bug-o-rama in Sacto.
It was a great trip except it needed a quart of oil every 300 miles. In Sacramento Jake decided to try new pistons and cylinders. A change was made from JE forged to Keith Black pistons and Charles sent brand new Nickies.
I put it back together again, this time one my own because Gerry was getting a little bored with dad’s engine. Sarah was interested in other things and Betsy was just plain sick of it. I had no joy again so Charles replated the cylinders and I reringed the top end. I also changed to new head castings. By this time I knew torque values by heart, I could drop the engine in a day, tear it down in a day and assemble it in another day. Of course, some things like the gears on the crank I wouldn’t need to change. I could put the engine back in, in a day and a half. All the while, Megasquirt was taking the blame for over- rich tuning and washing oil out of the cylinders.
This time it lasted a weekend. I detonated it on an uphill stretch of highway at 3000 rpms. I heard a can of marbles being shaken behind me. I got it towed home and oil was everywhere. I was ready to deep six it in Puget Sound. I almost could have walked away. At this point Jake again offered to build it and break it in. But, I hate to quit so he said come down and build it at my place. So, I scheduled a week of in September and headed for Air Cooled Heaven
The plan was for me to build it on Monday, Tuesday and Wednesday, put it on the dyno Thursday, break it in and tune it and then pack it up Friday. That was kind of ambitious and it all went pretty well until Thursday. I had a few issues with the build. First, when Jake says clean he means just shy of sterile. They use white lint free paper towels like large lens paper and wipe parts with carb cleaner. If there is anything color of mark you do it again until there isn’t any stain. That meant ½ hour per cylinder cleaning and these were freshly plated. Clean, clean, clean!!!! Everything that can’t be wiped gets sprayed and then blown off. Second, clearances are rechecked after the parts are heated I know exactly what the ring gaps are at 400 degrees and 24 degrees. I know I shouldn’t start my engine below 20 degrees. I asked a ton of questions and if it was something dumb, Brent’s right eyebrow would go up. He bailed me out many times. Anyway, after 19 hours of work on Wednesday it was ready for the dyno on Thursday morning.
Thursday morning was probably the worst morning of my adult life. I could not get a tach signal so MS wouldn’t work. I tried everything and I had no success. In tearing it down for carbs I almost started a fire in the dyno room and Jake grabbed a red hot 10 gauge wire that grounded accidentally to the dyno stand and pulled it apart. He ended up with 2nd degree burns on his hands (that’s the pound of flesh). From that moment forward Megasquit became Megapuke. There was some mention of a handgun that fired 12 gauge shotgun shells called “the Judge”. I was really hoping they were going to shoot my MS and not me. (They didn’t do either but, I may still send it back there for target practice). After lunch and Jake taking a while to cool off, we broke the engine in and got a pull of 209hp at 6500 rpm. It was the first 2270 to make over 200 hp on pump gas. Jake was so exited he was literally jumping around. He couldn’t explain that, the combo was a complete surprise.
I left Georgia with mixed feelings, I was glad to have a great engine but, it wasn’t done. It was clear I wouldn’t run MS with it. It was also clear the stock intake wouldn’t support that output so, we sourced the SDS stuff with individual throttle bodies and Jake offered to dyno it again if I come back down and install everything.
So, I made another trip in January to Georgia (by the way it snowed twice). The FI was installed and we had a pull of 212hp at 6000rpm.
I packed it up and shipped it home. The engine now has a good 8 hours of dyno time with 2 good leakdown tests so I’m comfortable that I have a really strong engine that will last. I’ve had it on the road and it needs a couple of tweaks but, nothing major.
It appears that my long adventure is very near an end. Ironic as it may seem, the pistons and cylinders are the original ones that came to me 3 plus years ago. As long and as hard as it has been, it hasn’t been without rewards. I know my son is very capable. He demonstrated that to me many times. I know I can see difficult things through. I’ve made new friends. I’ve learned way more than I bargained for. The time and effort has definitely been worth it
And, above all else I have a great respect for the people I dealt with. I hope this adventure of mine helps everyone appreciate what a treasure we have with these guys. I have been supported for over 3 years and it included an invitation to work in Jake’s shop. It still boggles my mind. I like to settle my debts but, I know I’ll never be able to repay these guys.
Thanks Jake, Charles and Len
Your Friend,
Dave
