markwemple
Apr 6 2008, 05:56 PM
Found a potential door replacement for my '70 but it is a '74 door. What are the differences?
Joe Ricard
Apr 6 2008, 06:09 PM
35 to 40 pounds per door.
Not only is there a crash bar in the late door but the siscor lift window mechanism is pretty heavy as well.
Apr 6 2008, 07:24 PM
QUOTE(Joe Ricard @ Apr 6 2008, 04:09 PM)
plus, the later window won't seal right against your early targa top ...
ask me how i know ...
Andy
markwemple
Apr 6 2008, 07:45 PM
If I only use the shell and install the earlier lift and glass and vent window, will that work?
Apr 6 2008, 08:11 PM
QUOTE(markwemple @ Apr 6 2008, 05:45 PM)
no. the door frame itself is different. the early mechanism and glass won't fit unless you do some major cutting & welding on the door ...
what's wrong with your old door?
Andy
markwemple
Apr 6 2008, 10:18 PM
Has rust on the leading edge including the area that holds the door seal. That is almost nonexistent. the majority of the door, including the bottom is very good, however. I just don't believe that cutting and welding is justified unless I can't find a replacement.
So, what years will work?
Apr 7 2008, 01:53 AM
QUOTE(markwemple @ Apr 6 2008, 08:18 PM)
'70 and '71 for sure. some (very) early '72 as well, but buying a '72 would be a gamble as it was a changeover year ...
Andy
914rat
Apr 7 2008, 11:23 AM
Actually 73 was the changeover year.The early 73 1.7 has the old style door and window regulators.
Apr 7 2008, 06:28 PM
QUOTE(914rat @ Apr 7 2008, 09:23 AM)
oops ...
Andy
roadster fan
Apr 8 2008, 04:24 AM
I have a 73 that has later mechanism's in early lightweight doors. Didnt realize it until i picked up two doors for my 71 and one was a lightweight and one was a later heavyweight with old style mechanism.
The weight difference is obvious.
Can't explain why I have later mechanisms in light doors though.
Jim
