QUOTE(jkeyzer @ Apr 7 2008, 06:25 PM)
Let me get this straight. As you were crusing along the freeway, in gear, the tach dropped to zero when you let off the accelerator, and then jumped back up to the right rpms when you put your foot back on the gas? And I am assuming you don't have an automatic...
The tach doing wacky things usually means a problem with the points. I would start there. The tach combined with bad idle screams points at me.
If not, maybe the battery is tipping against something when you decelerate and shorting out? Grasping at straws now...
Yes in gear at speed tach goes to zero when the throttle is closed, open throttle rpms jump back. with throttle closed if I put in the clutch the engine is off, let the clutch out engine on. come to a stop throttle closed engine is off. open throttle turn ignition on engine starts let out clutch and go. the engine runs fine. started at first attemped this morning and idled at 1100 rpm until theAuxiliary Air Regulator shut then the engine stopped. This in not a case of poor idle this no idle. this happened suddenly. It has petronix no points.
