jesiv
Apr 9 2008, 10:21 AM
Ok, I know my teener is the only one that has an oil leak. But my real problem is how to remove oil spots from my concrete driveway. Does anyone know a good way to remove oil spots.
Regars,
James
r_towle
Apr 9 2008, 10:22 AM
HD sells a great product. not what I use though.
I am old school.
I pour kitty litter on it and allow that to suck the oil out of the concrete for a day or two (if it rains, start over)
Put a plastic sheet over the kitty litter to keep it from getting dew on it at night.
After one or two on the final round, use less litter and use a small 2*4 about a foot long and grind the kitty litter into the concrete while using the board like a sponge...swirl it around .
You wont see the stain after that.
Once you have it cleaned up, seal the concrete so it will no longer absorb the oil.
Also, old cardboard makes a great parking spot.
Rich
stateofidleness
Apr 9 2008, 10:33 AM
pressure washer and a good degreaser
let the degreaser sit on it and do its work for a bit... scrub it real well with a scotch brite or other spongelike object.. let it sit for a bit
then take the pressure washer to it
jasons
Apr 9 2008, 10:37 AM
Oil Eater (from Costco) and a wire brush. More aggressive treatment, Muriatic Acid, but it can actually bleach the concrete if used full strength.
I would avoid the Muriatic Acid just because of toxicity, but it works damn good.
ericread
Apr 9 2008, 10:52 AM
"Is my teener the only one..."
mudfoot76
Apr 9 2008, 11:27 AM
I've always had really good luck using powder dishwashing detergent. Just cover the spot and leave it alone. Between dew and rain, the stain is eventually removed. But then my teener had never left a spot larger than a 50 cent coin. If you had more of a 'spill' than a 'spot', something more intensive would be in order...
Justinp71
Apr 9 2008, 11:32 AM
Can of Brakeclean and some rags normally does the trick...
VaccaRabite
Apr 9 2008, 11:39 AM
Nuke your driveway from orbit. It's the only way to be sure.
Zach
(I use kitty litter)
TheCabinetmaker
Apr 9 2008, 12:06 PM
Portland cement. cover oil spot and forget it.
1970 Neun vierzehn
Apr 9 2008, 12:13 PM
If someones' POS car or a delivery truck/van "spots" my driveway, I grab whatever liquid dish detergent is under the sink (Dawn, Ivory, Joy, Palmolive, etc.) and squeeze some of the soap onto the spot. I just let it sit until the next hard rain, and then it's gone. Twenty year old driveway, no oil stains, cracks yeah, but no spots.
Paul
Steve Thacker
Apr 9 2008, 12:15 PM
100% oil /grease removal. (I posted this before)
Step one go to Lowes / Home Depot and in the paint section buy M.E.K
Methel Ethel Keytone. Otherwise known as Methel Ethel Badshit.
Buy rubber chemical gloves ( Required as this shit will kill you)
Go to oil spot and douse it with the MEK, wait two minutes and take a cotton rag and blot the spot. Best to step on the rag.
Pull up rag and watch the magic as it dries
Earl spot is gone,...gone...gone.
BURN the rags if all possible! As MEK can stay in the ground for twenty years or more. So, please do not throw in the trash.
ericread
Apr 9 2008, 12:17 PM
QUOTE(Steve Thacker @ Apr 9 2008, 11:15 AM)
If you burn the rags, doesn't that just put the chenmicals in the air that you are breathing? Seems dangerous to me???
degreeoff
Apr 9 2008, 12:33 PM
Just leave 'that' spot for future parking........its goina happen so why fight it?
Steve Thacker
Apr 9 2008, 12:35 PM
Dear Teener Brother,
Do not hold your head over the flames and huff it in
However if you are persistant.
I hope you are in heaven before the devil knows your dead
Dr. Roger
Apr 9 2008, 01:08 PM
LOL.... if we only put as much effort into correcting the oil leak as we did into oil clean-up....
I'm soooo guilty of this too. =)
I thought using different valve cover gaskets would fix my leak but, in fact, it was the source of it. "An ounce of prevention..."
horizontally-opposed
Apr 9 2008, 01:19 PM
Tabasco sauce will do the trick on cement, but you've got to be careful with it as it will bleach it, too (and less toxically). I learned about it when cleaning up a spill at Costco in high school. I went and cleaned up a big jar that a customer dropped on the polished cement floor. I got what I could with two pieces of cardboard and a box. After I mopped up the remainder, I walked away.
An hour later (or so), I walked by the spot and had to do a double take. The floor was bleached light gray in the EXACT splatter pattern.
pete
I think I'd want to experiment with time/amount to get the Tabasco idea right for your application, but consider it another route if the above (very good) ideas don't work.
pete
Rand
Apr 9 2008, 01:26 PM
QUOTE(1970 Neun vierzehn @ Apr 9 2008, 11:13 AM)
Dish soap cuts oil real well. It's nice not having to go pick up something special from the hardware store.
If there's a spill, then kitty litter to soak up the excess first.
For larger spills, Zach's idea is slick. Except this one time I miscalculated the trajectory and took out the neighbor's driveway.
roadster fan
Apr 9 2008, 03:49 PM
taught to me by my dad:
put a little gas on the oil spot as solvent
scrub if it is a old stubborn stain
immediately apply kitty litter and let sit for a few minutes
sweep up
No more stain!
Jim
Gint
Apr 9 2008, 03:51 PM
I use normal degreaser kinda junk. Spray it on and let it dry. The first rain or snow will usually take care of it after that. If it doesn't the first time, it will the second time. No fuss, no muss, no scrubbing. Now that I have Oil Eater I'm trying that too. I'll let you know what happens after tomorrow'as snow storm.
I also use Dawn dishwashing detergent to clean my greasy hands and gloves after working on the greaseball. That stuff works great! So I'll have to try that on the driveway as well.
I'll definitely try the Tobasco! Plenty of that around my house.
biosurfer1
Apr 9 2008, 05:25 PM
"Muriatic Acid"
thats some bad, bad stuff. We had a large can of that explode at the dealership when I was a detailer, lucky no one was around. It sprayed everywhere and started eating through 2 cars...not very stable!
I use the purple concrete cleaner from HD, worked great in my garage, have not tried it on the driveway yet...
Gint
Apr 9 2008, 05:29 PM
That's exactly what I meant when I referred to "normal degreaser kinda junk." That's what I normally use and it works fine.
This time it's Oil Eater though. I just put another coat of it on the driveway. Just in time. It's all pre-snow storm windy and gusty outside and the temp is dropping fast.
Crazyhippy
Apr 9 2008, 06:48 PM
QUOTE(r_towle @ Apr 9 2008, 09:22 AM)
Rich
I just drive onto the kitty litter... Use the weight of the car to crush the kitty litter for a few days, and Viola....
Hardest part was working the broom.
Oh yeah, and it's not nearly as toxic as some of the other ideas
BJH
Pat Garvey
Apr 9 2008, 07:40 PM
QUOTE(horizontally-opposed @ Apr 9 2008, 01:19 PM)
pete
When I was a much younger pup, working as a chemist (70's), I used so much MEK for my work that I no longer have ANY brain cells! I did develope a serious taste for Tobasco shortly thereafter.
So, when I have an oil leak I sprinkle it with Tobasco, and a spridgen of saffron - gives it that Tuscan flavor. Then I just lick it all up. End of spot & dinner taken care of. I have several other variations - you should write for my recipes.
Pat
jesiv
Apr 9 2008, 11:12 PM
Went to CostCo to get OE and there is none available in the bay area.
Regards,
James
PS Zack, I like your thinking...
Oil eater from costco. I got mine in Santa Cruz. Works great.
LarryR
Apr 9 2008, 11:25 PM
+1 on muratic acid in its incredible efficiency. It will leave your driveway looking like new.
Wear a mask and neutralize with water what more could you ask for. Reseal when done. Then you can use a pressure washer in the future.
Just go to your local pool supply store and 20 bucks later your driveway looks like new.
GaroldShaffer
Apr 9 2008, 11:37 PM
QUOTE(Crazyhippy @ Apr 9 2008, 04:48 PM)
Rich
BJH
If doesn't get it all I use a product called pour and restore. Leave on teh oil stain, let it dry and sweep up.
spare time toys
Apr 10 2008, 12:45 AM
GO here and get this stuff
http://www.completegarage.com/Pour_N_Resto...n__P146C153.cfmIt is great. I have used it to pull out old stains.
roadster fan
Apr 10 2008, 03:08 AM
Uhhhhhhhhhh.........
"the benefits of a liquid de-greaser with a dry absorbent to dissolve and absorb concrete oil stains."
even at $3.80 a gallon for gas and $4.00 for a 20lb bag of kitty litter I think you can save about $32.00 by using the gas and litter to lift your stain.
just my .02
Jim
arvcube
Apr 10 2008, 08:34 PM
engine/motor flush in a spray bottle works for me....and the cardboard deal..
