QUOTE(Cap'n Krusty @ Apr 10 2008, 02:47 AM)
I use an "Ozzy" parts cleaner, mostly because the county mandates a non-petroleum based machine. It uses heated fluid containing microbes that live on oil. You can't turn the heat off for more than an hour or so, and you have to feed it a bit of oil during extended periods of non-use. It removes oil pretty good, but it doesn't do well at all with grease. Works well on brake fluid and dust. A lot of hand work is required to remove caked on dirt. We have to top off the fluid regularly, and change the particle filter at least once a month. Supplies are relatively expensive. Good on your skin, and the heat is nice. Non-toxic, and waaaaay better for you than solvent immersion. Doesn't dry out your skin, either. It's possible the Costco machine is similar, and the solvent may not work cold. Ours won't even survive unless the temps are kept relatively stable (once the liquid has been put into use).
The Cap'n
Feeding your parts cleaner seems a bit sci-fi to me..and creepy.
I know its new, it works, and its better for the world...got that.
It still creeps me out.
Rich
