QUOTE(jesiv @ Apr 10 2008, 11:20 PM)
Chris,
How did you get the blue to mount or what part # blue did you get. The new one I got was too small in diameter to use the stock coil bracket.
That is how it was set up when I bought the car. I actually have a new coil coming today and I hope it is the same diameter or I'll be fabricating a bracket.
Nice looking motor. Sorry to highjack but does the removal of the intake box improve performance?
Absolutely, at least .25hp.
I had the K&N air filter sitting on a shelf. I had an extra air intake sensor and realized that the flange on the elbow side fit the filter so I removed the flange and bolted it to the AIS on the motor, made a brace for the sensor and it fit perfectly in the engine compartment.
I'm still sorting out what appears to be an intermittent electrical problem (which I hope a new coil, points, and condensor resolve the issue) and I replaced the junky HEs with 2.0 SSI HEs. Those are what I chalk up the increase in power to.
