QUOTE(BMartin914 @ Apr 12 2008, 11:47 AM)
You need to match the components with d-jet. You can't just mix and match MPS, TSII and ECU and expect it to run right. You're going to create more issues trying to "fool" and "tweak" your various components.
All components must be "matched" for the year and the engine. Anders lays it all out on his site...
This has been disproven.
With a resistor, you can use any CHT.
I am more interested in two things.
What is the difference? this is the car to have...is the ECU better or worse?
More or less power?
The MPS and CHT can be tuned in car with a wide band O2 Sensor, and I know just the guy to borrow it from.....Drew did this last year.
He actually put a POT inline with the CHT. He drove around and kept changing the POT until the OS sensor was reading what he was aiming for.
He then used a meter to read the POT, went to radioshack and purchased the correct resistor.
So, the CHT is really not to hard to figure out.
But again...is this the more power ECU, or more Ecomony one???
Rich
