QUOTE(ejm @ Apr 13 2008, 04:53 AM)
QUOTE(computers4kids @ Apr 13 2008, 03:16 AM)
What's up with the plate???
Just a WAG but since the engine has carbs maybe it covers a botched attempt to drill the case for a mechanical pump.
Well, here is a shot of that cavity with the block-off plate removed. I don't know if you can tell from the picture but, it definitely has some sort of shaft inside tapped into an oil gallery. Does anyone else have a clue....????
QUOTE(hcdmueller @ Apr 13 2008, 04:58 PM)
Definitely A/C tensioning pulley. I just pulled one off my engine a couple months ago. You can see where the cylinder tin is chopped up for the compressor install. Your heads are definitely not 75/76 either. My 76 heads don't have breathers on them.
Yep, I can see the other pulley spoken of earlier if you look up behind the fan housing.
Heads have these numbers:
039101371A stamped inside valve covers.
