PanelBilly
Apr 13 2008, 07:20 PM
Click to view attachmentI've been working for the past year to make the steel flares I got from AA fit just right. I worked so hard to make them match the curve of the fiberglass rockers that I had ordered at the same time. You can see from the photo that the black of the rockers is a match. Now I've moved on to the fit of the rockers and they just aren't right. To start with they are so much thicker than the seel ones that came off. I don't see how the threshold plate (or whatever you call the aluminum plate that is on the bottom of the door opening) will fit proper if the rocker is so thick. I still have the original steel ones. Has anybody tried to blend the front and back flare of the fiberglass ones to the stock metal units.
Any other ideas?
burton73
Apr 14 2008, 12:01 AM
I need to see a better picture. Not all glasswork is the same and most will take a lot of massaging. The first company I got a set from did not fit well. The second needs to be lengthened on the driver side by ¾ inch. I will say this, Marty has perfect rear valance to fit the GT contour but the sides are not perfect. My car is just getting on my rotisserie this week. I hope AA Factory GT molds are right as will save a lot of time for everyone flaring their cars.
Bob
PanelBilly
Apr 14 2008, 12:10 AM
I'm assuming the metal flairs were a match to the original, but the rockers had a totally different radius especially on the front side of the back wheels. I worked the metal to match closely and the used polester filler to finish off the curve. Since I don't have the front and back valance, I'm wondering how close they will match.
I guess I'll order Marty's parts and modify them to fit what I have.
degreeoff
Apr 14 2008, 07:55 AM
My thread has a show and bit#$ about fitting the bloody things!
tracks914
Apr 15 2008, 09:33 PM
boxstr
Apr 15 2008, 10:29 PM
I have had to have two sets of rockers made for flared cars. Both were done by hand by Steve Hebert and they came out perfect.
This is not an easy task, but if given to a real craftsman you will not be disappointed.
CCL
PanelBilly
Apr 15 2008, 11:58 PM
QUOTE(boxstr @ Apr 15 2008, 09:29 PM)
CCL
So did he make them out of steel?
914Sixer
Apr 16 2008, 02:38 PM
You have to remeber that all the 916'S that were built were PROTOTYPES. With that said, all of the cars were hand built. SOOO, the flares were never in the same place. No matter which car you pull the molds off will be the same.
Here is an option I am working on. POOR quality AIR flares that are going to be molded onto stock fiberglass. This way I can "adjust" my ends to where ever they fit the best.
lotus_65
Apr 16 2008, 07:39 PM
is this thread just a ruse to show off how sweet your flares fit?
nice work.
