i did a bit more googling in some spare time.
i'd looked into all this 6 months or more ago.
lots of too and fro-ing on decel valve discussion on this site in the past and on other porsche vw sites.
i did find this one.
https://itinerant-air-cooled.com/viewtopic.php?t=13891contains an interesting post from the administrator half way down the thread.
gives an insight into the endless array of decel valves (and variety of part #s) and a hint of some of the vacuum settings and what they will produce. including cal spec aircooled vws being set up with a different vacuum setting to rest of USA. also higher altitude settings are mentioned.
seems to me any of these decel valves, similar in appearance with an adjustable nut could be made to do the job for a 914. so long as you know the vacuum setting you are after and can achieve it with the adjustment it ought to be a goer. including the one at start of thread if its a decel valve.
which is of interest to me because there is one lying around on a pile of parts from an early 911 engine in the workshop. its the small 914 shaped one. its got a nut on it.
i might take a closer look at it and see if its workable and report back. i'm kind of half interested in installing one properly adjusted to see what it does. its pretty simply plug and play stuff to put it on the engine. crazy prices for ones for sale stopped me going further 6 months ago. ironic that a part everyone was binning half a century ago is now rare and sought after.
i'm not so sure about the later big one fitted to 1.8s being a good choice. its not adjustable. so its take it or leave it - you would have to hope its still in good order.
but i'm satisfied now that my earlier 74 did run the small one, not a big one.
i found something from dave darling on that and he would know.
close match here for one at top of thread, but not quite a cigar.
80s passat and audi.
looks like vw charge 9 euro for a bracket.
i think the heritage part site will only throw up parts in stock, so it likely does not do a historical search for a part that once existed?
