kconway
Apr 14 2008, 10:20 PM
I pulled off the oil filler assembly and removed what I thought was the PCV valve for cleaning. Full of gunk so I thought I'd clean it up. There is a small gasket on that PCV valve that crumbled in my fingers. Checking Pelican, it says the PCV valve is NLA.
What does the PCV do? Do I need it (djet, bone stock)? Is that assembly normallly serviced, cleaned? Where do I find that gasket?
Thanks,
Kev
JeffBowlsby
Apr 14 2008, 10:31 PM
kconway
Apr 14 2008, 10:37 PM
Ha! Thanks Jeff. I just got done reading that and was going to post an answer to my own question. Shame on me, I should have known to look there.
So..are these truly NLA? Brad's text has conflicting info on availability.
championgt1
Apr 15 2008, 12:02 AM
I have the same problem with that gasket. I tried to get one from AA but they also do not have any. Went to the local auto parts store and bought some oil plug gaskets about the same size. I have not got around to putting it on yet, so I'm not sure it will work. Seams like all the used ones just crumble when you touch them.
Dave_Darling
Apr 15 2008, 10:09 AM
If the valve is dead, you can try substituting a restriction instead of the valve. It will be open a little bit at all times, instead of being open quite a bit only at certain times. Ray Greenwood over on the Shoptalk Forums Type 4um talks about using a disk with a small (1mm or maybe smaller?) hole in it.
--DD
