i have noticed a small issue on my rear taillight when i turn them on. It appears that sometimes when i turn on my lights, my left side doesnt turn on. All it takes is for me to go into the back, hit the corner of the rear, and it turns on. Would the problem just be that the light isn't all the way in, so the connection isnt that good or what? At first, i thought it was either a dead bulb (but the brake light worked, so that was ruled out), then i thought a bad fuse (til i found out that tapping near the light worked)
i havnt really looked into the issue, and since im going home this weekend, i figured i should find out. All my others lights work (except for the side reflector lights for when the lights are on (in the corners) casue they both burned out, and i didnt see the need to replace em.
Since i will be home though, i figured ill try to fix the light (and find my brake line leak)
so any tips, or suggestions, before i really look at the problem will help. Thanks
