QUOTE(Wes V @ Apr 17 2008, 03:06 PM)
As is pretty typical, I've got rust bubbles showing in the body above the door handle;
My feeling is that this is caused by the fact that the factory waterproofing captures any water that gets through the trim attachment hole just above it.
I'd like to remove the waterproofing so that the rust can be treated (Por15) and then put on a thin coat of underseal, that would allow the water to drain away.
The following photo shows the back side of the panel and the blue arrows point where I want to remove the factory waterproofing.
So, any ideas or recommendations as to how I get that crud out!!Wes V
Wes,
I would not use a torch around the vent tube. That is a leaded seam and heat will pretty much flow the solder right off the tube/ pillar. Unless you want to learn a new trade (tinning) no torch.
Spray the backside at the undercoating liberally with WD40 and let it sit overnight. This will soften the coating and creep a underneath.
Get a 5/8 or 3/4 inch heavy twist wire wheel (on the die grinder) and this will remove any coating in about 30 seconds down to bare metal. Wipe area with acetone when finished to remove any oil residue.
If you need to MIG a patch in go slowly as to not melt the lead and you should be fine.
