eldiosyeldiablo
Jan 18 2004, 06:46 PM
The red wire coming from the bottom of the aux air valve is not connected to anything.
Where is it suppose to go?
Thx,
David
eldiosyeldiablo
Jan 18 2004, 06:47 PM
View #2
eldiosyeldiablo
View #3
redshift
Jan 18 2004, 07:08 PM
See where the TACH wire connects to -, connect that wire to + (THE OTHER SIDE)
On the coil, near the green wire in your other pics.
M
TheCabinetmaker
Jan 18 2004, 07:20 PM
The red wire from the AAR attaches to another red wire coming from a wiring harness that comes from the rear part of the motor and "should" run under the right side intake runners.
Jan 18 2004, 08:10 PM
yupp, AAR get's 12V constantly, always on, no switch or anything ...
there should be a wire for it in your engine harness, near the intake plenum.
Andy
Dave_Darling
Jan 19 2004, 12:42 AM
It should be a white wire, and it should be connected to the right-rear pin of the 12-pin connector at the right-rear of the engine bay. Gets +12V when the fuel pump is running. Don't put it on the coil; you want the coil to get all the power it can.
--DD
redshift
Jan 19 2004, 08:43 AM
hey, I just found a problem
M
eldiosyeldiablo
Jan 19 2004, 11:58 AM
What problem is that?
Your problem or one of mine?
-David
