QUOTE(lonnie152 @ May 6 2008, 11:08 AM)
very much appreciate all the suggestions. Unfortunately am not smart enough to understand all which has been offered and so i remain stuck. since i have now replaced all the fuses and relays believe the problem to be in the board itself.
So unless i get any advice to the contrary, tonight i will pull the board, chip away the underneath coating and use a voltmeter to test all the connections. any suggestions on how best to do this would be great and again thanks to all for the help.
We can help you debug this, but you need to be our "eyes" and "hands".
Don't let this get you bummed out.
We do need a bit more information to help isolate the problem.
The biggest question we still need to know is how you have wired in your
fuel pump and what you have tried.
Are you referencing/using the online technical article?
Here is the link to it:
FuelPump wiring for CarbsIt shows a simple way to hook up a fuel pump for carbs and has some
really good photos which identify and label relays, connectors & wires.
If you scroll that WEB page down, you will see a photo of a relay board.
That is the picture that has the locations that I was referencing in the
very specific questions I asked in post #23 and post #25.
From the information you've provided so far, it isn't clear that it is a relay
board problem yet.
It's not worth tearing into the relay board looking for something
before other possibilities are ruled out.
Should it turn out to be a relay board issue you don't have to chip away any
of the undercoating in order to test the relay board,
so I wouldn't mess with any undercoating yet.
Also, a big clue on relay board failure can be how the undercoating looks
before you remove it. If there are open areas or melted areas, that area
should be looked at very closely because the rivets in those locations
may have oxidized or worked loose. But again, I wouldn't touch the
relay board, until other possibilities have been ruled out.
If you are totally stuck and want to talk directly, PM me
and we can exchange phone numbers. I'll be happy to help
you out. Just let me know.
--- bill
