Ray Warren
Jan 19 2004, 07:23 PM
i'm not sure what O rings i need.
i know one end has 8 black but the other
end could be red or green according to
the pet cd.
engine is a 73 1.7
also, i read the tech article on 914fan.net
about doing this job while the engine is in the car.
has anyone done this?
TheCabinetmaker
Jan 19 2004, 07:28 PM
yes, it can be done in the car. Not sure about the color.
trojanhorsepower
Jan 19 2004, 07:37 PM
I did mine with the motor out. The top ones are green, but I don’t know if they are considered to be the best. Do a search for “pushrod tubes” and see what Jake and Brad say. I think it is something like Vitron? "V" something any way. Jake gives a good explanation in that thread. I will try to find it and post something useful.
-Pete
415PB
Jan 19 2004, 08:01 PM
The top ones should be green. I did mine while the engine was in the car, it was actually pretty easy.
Matt Romanowski
Jan 19 2004, 08:12 PM
Hello,
The green ones are viton and are usually considered to be the best. They seem to last the longest, although they all work. It is easily do-able in the car. Make sure you lube them before inserting the tubes.
Matt
Rich Bontempi
Jan 19 2004, 08:20 PM
For a 73 1.7 you should use the green ones which are the better quality. We use the green on the head and the case side!
