My car was delivered yellow in 1969 then at some time it was painted green. The PO removed all the paint from all exterior surfaces with paint remover. (I know this because I find some hard goop in behind the doors) but not from the trunks and engine and then painted it metallic brown some time in the late 70s. I have been removing all the paint with 3M pads with air die grinder and 60 grit-sanding disks. I have removed all paint from the doors Front and rear trunk lid and engine lid and then put the engine lid in my bead blaster to remove all the color from the inside so I can do a perfect color change. When I remove the paint I find small areas where the paint seems like it had water in it or something and that caused bubbles in the paint. This car sat in a garage in Southern California for the last 18 years and it is an original Southern Southern California Cal. Car.
The thing is there are these small rust like spots after I remove all the paint. There are in the arrears where the bubbles show in the brown paint. This is like weard surface rust. It is not coming from behind. I have clean panels and the backsides are clean. I cannot pick at them. They are so small.
I do not want this to creep out from under the new paint job.
What to do,
Bob
