dandh
May 2 2008, 02:27 AM
Got most of the stuff I'm going to need for the big brake change this wk end,rotors,seals,calipers pads,hoses,bearings, ? should I change out the m/c too ?
a 19 mm MC is available which is an improvement over the stock unit.
Eric_Shea
May 2 2008, 05:12 PM
Depends... are you using stock calipers up front?
A 19mm will give you a harder pedal but it will take more effort.
You mention big and change in the same sentence. If you are going to a larger pistoned caliper up front then you should change to the 19mm
E.
