QUOTE(LowGT @ May 4 2008, 10:24 PM)
Is there any reason why aluminum tubing would be bad to use rather than SS tubing for the fuel line in the center tunnel? It's cheaper, and easy to bend.
I used aluminum on a previous 914 I had that had carbs and it worked great. Looking at the same project for my 1.8 L-jet, just curious why I don't see people using the aluminum tubing.
Dan
You can't get into the tunnel to properly clamp the line so the aluminum will work harden and fracture in the tunnel. And gasoline leaking anywhere is very bad. And a car fire is much more expensive than some stainless tubing. BTDT!
Get the kit and replace it correctly. It's easy. You can even do it with the engine in the car.
