Rand
May 4 2008, 11:37 PM
Pulling the late model exhaust off my 4. Six of the eight nuts are no trouble, but those forward outer ones are too close to the header pipe to get a socket on. What do you use? Can you get a thin-walled socket at the FLAPS that's thin enough to get on there?
arvcube
May 5 2008, 12:30 AM
QUOTE(Rand @ May 4 2008, 10:37 PM)
Try using a deep socket, extension and wratchet that's 1/4". That's what I used. good luck
lagunero
May 5 2008, 01:23 AM
QUOTE(arvcube @ May 4 2008, 11:30 PM)
Same, but I had to ground the socket down a bit.
bperry
May 5 2008, 01:00 PM
I had the same problem about 10 years ago. I went to Sears and bought
a deep socket. Some of them have much thinner walls than others.
I was able to find one that had very thin walls.
--- bill
URY914
May 5 2008, 01:20 PM
The thin walled sockets are the cheap ones (less metal=cheap) but be careful they will split on you. Buy several.
rjames
May 5 2008, 01:37 PM
PM sent Rand, I have one you can borrow that worked well for me.
Joe Bob
May 5 2008, 02:03 PM
Can you get a box end wrench in there? I've bent a few into an "S" curve and that works.....are they 12mm or 13?
Rand
May 5 2008, 02:09 PM
13mm, and I thought about bending a wrench but it doesn't like like it will fit up in there. I'll look again.
I think I'll grind down an old socket. If that breaks I'll go buy a couple of cheap thin deep sockets and grind if necessary.
Robert, if you happen to be over this way tonight give me a buzz.
Thanks gang!
Squeeze a flat-head screwdriver in there and pry it out a little. The HE will push over a small amount.
Dave_Darling
May 6 2008, 10:09 AM
I was (barely) able to use a 1/4" drive Craftsman socket to remove the exhaust nuts, back when I still had the original 13mm ones on the car. The replacement 12mm nuts are easier.
On some 10mm nuts, I have found that my Snap-On 1/4" drive socket is slightly thinner than the Craftsman. I would assume the 13mm would similarly be thinner.
--DD
May 6 2008, 12:00 PM
