Rusty
May 6 2008, 02:48 PM
I've collected a great about of 914/6 carb info... including a vintage Weber manual and a ton of other good stuff about adjusting /6 carbs.
Unfortunately, it's in my pigpen of a garage. I looked for almost an hour yesterday... no luck.
Anyone got a detailed set of instructions on baselining and tuning 914-6 carbs?
Gint
May 6 2008, 06:03 PM
I've got something form years ago... I'll see if I can find it. I'm sure Perry will post by this time tomorrow.
elmonte
May 6 2008, 06:20 PM
IronHillRestorations
May 7 2008, 10:49 AM
A copy of a copied post:
Assumptions: the carbs have the optimum jet and venturi package (good luck on this one), the float level in the carbs is correct, the cams are correctly timed, the valves are properly adjusted, the ignition timing is dead on, you have the proper spark plugs for your engine, the linkage is good, the fuel is good, the engine is good.
Remember that the mixture and air bypass adjustment screws are precision needle valves, not head gaskets. Use your fingers to tighten them, not your fist.
Start and warm up the engine.
Make sure the two drop links for the throttle linkage are exactly the same length, and disconnected. You can use a 8mm thin igntion wrench to snap them off.
Turn the mixture screws all the way in and then 5 half turns out.
Turn the air bypass screws all the way in.
Turn the idle speed screws out til it just touches, and then in 5 half turns.
Put on your hearing protection and start the car.
Use your STE and find the barrel that pulls the most. We'll call this one baseline.
Balance the barrel in the other carb that pulls the most with the idle speed screw. (if you have a Uni-syn, give it to someone you don't like and purchase a STE airflow meter)
Go back to the other carb, with the baseline barrel. You will have one all the way in, then use the air bypass screws and balance the other two barrels.
Go to the other carb and do the same thing.
Snug the jamb nuts on the air bypass screws.
All six barrels should pull the same amount of air at this point, if not repeat air adjustment proceedure.
Snap the throttle linkage drop links back on the carbs. If the idle changes then you need to barely adjust the linkage mounts so snapping the drop links on, doesn't change the side to side idle balance.
Use the hand throttle or a vice grip and rag to lock the linkage between 1400 and 1800 rpm.
Start back at the baseline barrel and adjust the mixture screw in or out, to get the smoothest running and highest rpm, then turn it in 1/4 turn.
Do the same with the five other mixture screws.
If you have to turn the mixture screws more than two turns either way, you've got the wrong jets.
Recheck side to side and individual air balance, adjust as needed.
Road test the car.
If you get snapping and poping out the intake, it's generally a lean condition.
If you get heavy exhaust fumes, or pboofing out the exhaust it's probably too rich.
If you get a flat spot or popping out the intake at between 2800 and 3200 rpm, you probably need larger idle jets.
That's a rough, five minute draft of my carb tuning proceedure, hope it helps!
If it goes good it should take about 45 minutes, if not about three years.
PK
Another good tip: If you think you have a lean cylinder (idle jet plugged) you can back out the jet carrier a half to one full turn and the engine should stumble, if it doesn't change theres a good chance the jet is clogged. This primarily applies to the 3 barrel carbs, as the 2 barrel IDF's have a different type idle jet set up (right Tim?)
purple
May 7 2008, 11:23 AM
man, that's a great guide. Can I assume this will work on carbed 914-4's?
