Purchased the 1974 2.0 914 about three weeks ago. Non runner, from shop.
Well it runs now. Replaced Spark Plug Wire, points and condensor. Removed Tach wire from Coil, it runs. Hmmm
So what works:
Motor
Tranny
Brakes
Suspension
Winshield and windows
Emergancy flashers
What doesn't:
Low Beams - Cleaned Ground bolts up front little dielectric grease now both High beams work, only one before. Maybe low beam on bulbs???
Tach - Removed tach lead from Coil, motor works tach doesn't. What's that about???
Fog Lights - Have no idea yet havn't gotten there yet.
Wiper - Nope, won't be driving in the rain. Ideas???
Seat belt Light - Non-op
Horn - Took off center Wire looks like it burnt once, there is a splice. Run new wire this weekend. Need a horn I sit lower, so I'm looking up at SUV Drivers butt. LOL
Temp gauge in left top side of gauge, What temp is that reading? Oil or head? I have a non stock Oil Pressure and Oil Temp gauge. Freeway Oil PSI 60 Oil Temp 180ish, Traffic stop lights etc. 210-230 is that about right?
Dwell is a little out of spec on the high side, will adjust Weekend.
Timing is a pain with one person, Aim Light, Twist Dizzy, hold RPM at 3500.
None of the fuses look burnt out. Put air in tires 40PSI, rides better. The top rattles, is there a way to tighten up that or would new seal quiet it down?
Tranny grinds on occasion, slow roll no problem, From reverse no problem, dead stop sometimes. I'm thinking clutch adjustment.
Would like to bend the Gear Shift over to the Passenger side about 3" as going from 1st to 4th looks bad. LOL
Tranny shifting feels hard/stiff Not sure if this is a good thing. Not sloppy and no movement once in gear, just overly stiff, any adjustment or items to inspect?
It is running very rich, black smoke out the exhaust.
Long post sorry it's were we are at.
Thanks for any suggestions.
Smitty
PS When my son assisted me in checking the FI Value, we removed the ECU the little knob on top he twisted around. I have no idea what it does. I attempted to click it back a couple but how is it adjusted.
PSS the screw on the side of the Trottle body, what does that do, I can't seem to find it in my Haynes manual.
