Blue smoke is usually oil. White indicates antifreeze. Is your coolant level dropping at all? Mabey a blown head gasket.
KIDDING!
White smoke can also be condensation burning off.
What does the exhaust smell like? if it smells like Gas, then you are rich. If it smells "right" then it may just be condensation that goes away when the motor warms up.
if the smoke does not go away...
http://64.78.42.182/sweethaven/MechTech/Au...10&modNum=1White smoke is generally most noticeable at engine start-up, particularly during cold conditions. As the combustion and cylinder temperatures increase during the first few minutes of engine operation the white smoke should start to disappear which indicates the engine is sound. However, if the white smoke takes longer than 3 to 5 minutes to disappear a problem exist. The problems white smoke may indicate are as follows:
* Low cylinder compression from worn rings (Zach's Emphasis)
* Scored piston or liner
* Valve seating problems
* Water leaking into the combustion chamber
* Faulty injectors
* Use of a low cetane diesel fuel.
Did you ever check your rings from a while back?
Zach
