QUOTE(jkeyzer @ May 8 2008, 11:45 PM)
The gravitational pull of the fuel in the tank counteracts the torque of the engine when the tank is full. At less than half a tank, the effect is reversed. The net effect is that with a nearly empty tank, the fuel is actually accelerated into the engine, like a tiny turbocharger inside your fuel pump.
Sooooo, the gravitational pull of the fuel... I have posted some BS remarks before, but this tops the chart! Let's see now, gravitational pull of an object is directly proportional to it's mass. Therefore, the mass of the gasoline would be so significant as to exert it's gravitational pull over the Earth's gravity and other large objects...
A very entertaining explanation, but it just doesn't hold water... er, gas.
Let's see... A gallon of gas weighs about 6 pounds. So a 12 gallon tank would weigh about 72 pounds. For shits and giggles, let's say that the weight of a gallon of gasoline = about 0.45 Kilograms at 60 degrees F (temperature is actually an important variable here). Thus, you have a mass of about (72 pounds times .45) 32.4 Kilograms.
So the 32.4 Kilograms of mass (the gasoline) is interacting with a significant gravitational force. Let's see, the other really big gravitational force is the Earth, which has a Mass of about 6,600,000,000,000,000,000,000 (6.6 sextillion) short tons (6.0 sextillion metric tons), or 6.0 × 1024 kg.
So in a contest of gravitational forces between the Earth and the gas, the Earth clearly wins. In fact, if it were true that there was a significant gravitational pull of objects which have a minor mass, say like a 50 story building, then the gas would be pulled to the building rather than to the engine. In fact we would all be pulled to the building. Bummer.
Nope. But it was fun to dissect. I haven't done this math in about 25 years, since I taught astronomy at a planetarium, so I may be off by a decimal point or so.
But it really doesn't matter, the gravitational pull of non-significant objects (say, smaller than the moon) just don't have any measurable effect, and thus, doesn't asssit in your car's performance.
Let's do this again sometime
