Oled
May 10 2008, 03:06 PM
I have been using a stock fuel injecton system on my 2.0 for almost 20 years. A guy I know came by the house yesterday to have me help him set his timing. Unfortunately he has twin Webers with a mechanical advance distributor. He had no reference material for settings. What is the timing set point for this engine that has a stock cam and stock pistons?
Cap'n Krusty
May 10 2008, 04:02 PM
Probably best to use the stock full advance mark and setting procedure. Might add in a couple of degrees, but no more than that. The Cap'n
Carlitos Way
May 10 2008, 09:24 PM
What's the "stock full advance mark and setting procedure"?
Am I the only one who doesn't know it?
C:>
SGB
May 10 2008, 09:35 PM
Its the "full advance" point, which should be at, what, 27degrees btdc? I really can't recall what the "static' timing point was with my Bosch 0.50 (I went to a Mallory). Seems like it was prety high- 10 or 11 degrees btdc. That ends up with a pretty high final advance. Thats b/c those bosch dizzies have steep advance (good) but to much advance at high rpms (bad) When you set based on the full advance, that can't happen. I think that is the value in the full advance concept is that you take a more conservative setting - less likeley to overheat.
