I cleaned the grounds near the headlights, took out the turn signal and side marker light bulbs and sandpapered them to clean contacts.
I still have the same problem. The front and rear turn signals work when the headlights are turned off, the rears work with the headlights on, but the fronts do not flash when the headlights are on.
Both signal indicators in the dash blink when the signals are turned left or right and regardless if the headlights are on or not. The hazard flashers work front and rear with the headlights off or on.
Its certainly possible that wires are hooked up wrong, but if so which ones should I be looking for?
This is a 73 with a six conversion in it. The car was dormant for over 10 years and I just recently brought back it to life.
