krazykonrad
May 11 2008, 07:56 PM
Which way do I turn the screw on the fuel pressure regulator for more pressure. I'm trying to compensate for a weak fuel pump that I'll replace in the next few days.
THanks!
Konrad
McMark
May 11 2008, 07:59 PM
In, clockwise, tighter.
Think tighten the screw for tighter pressure (more), loosen the screw for looser pressure (less).
krazykonrad
May 11 2008, 08:02 PM
THank you very much!
Konrad
Dave_Darling
May 12 2008, 01:01 AM
Turn the direction that makes the needle in your pressure gauge go up!
If you're messing with the pressure, you really should have a gauge on it.
--DD
914Sixer
May 12 2008, 06:53 AM
Leave it alone until you get a new pump.You really need a guage in line to adjust it though.
davesprinkle
May 12 2008, 09:41 AM
If your pump can't flow adequate fuel at the stock pressure, it won't be able to flow adequate fuel at a higher pressure. Don't eff with the pressure reg. Get a new pump.
