whitey
May 12 2008, 01:50 AM
My new 19mm MC has only one wire connection for the break light...which of the two wires from my wiring harness do I connect?
Thanks, Dave
Dr. Roger
May 12 2008, 02:32 AM
on a '74, it's referred to as F6, the brake warning switch wire.
brown with a yellow stripe.
seen here.
http://www.pelicanparts.com/914/parts/Elec...lectric_74C.jpg
914Sixer
May 12 2008, 06:50 AM
Both wires. You need to take the switch off your old master cylinder. Cars up to 74 have a ballast connected on the hand brake behind the dash. If you need a new one I have 2 left. I believe they are no longer available. $30 shippped Priority Mail.
jasons
May 12 2008, 09:07 AM
I don't think you necessarily have to use the old switch. The BROWN wire is just a ground lead. The 19mm switch grounds through the M/C to the chassis.
At least thats what I see on the 73 electrical schematic.
Dave_Darling
May 12 2008, 09:26 AM
Exactly--just plug the brn/yel wire in, and tape the brn wire out of the way.
--DD
