yellow1
May 12 2008, 02:23 PM
My tach is not working, i want to make shure the connections to the tach are all secure ,does the steering wheel have to be removed or can it stay on.with the wheel on can the pannel be pulled out enough to see the back of the tach i just want to be able to see the back of tach make sure everything is connected and okay back there.Thx
914Sixer
May 12 2008, 02:43 PM
The tach comes out straight foward. You might want to put some tape across the top of the steering columun to prevent scratching. If the dash top is bowed down this can cause a clearence problem with the tach also.
Check the purple/Black wire on the engine harness to make sure it is plugged in or not broken off.
smooth_eddy
May 12 2008, 08:47 PM
There are 4 screws on the metal instrument cluster panel (sometimes 5 and 6 are below?). Just remove the screws and carefully pull the cluster forward. If you need to romove the tach, it just pushed out.
Eddy
