QUOTE(vesnyder @ May 13 2008, 12:20 PM)
Rebuilt my motor about 400 miles ago and it had been running fine until today when I decided to take it on a 120 mile round trip! About half way home it started missing bad and the tach jumped all over the place. I made it home (thankfully). The car idles fine but when undser power it misses a lot. Where do I start - coil, plug wires, plugs, distributor, cap, condensor???
HELP!!
Yep.
Only three things to check: gas, spark and mechanical. Assuming mechanical is OK, is this a fuel starvation issue? Possibly the fuel filter fouling? If not that, then how about the spark? All your spark plug lines all attached properly? You might want to pull the plugs to see if any of them are fouled.
With your description I would look for 1) fuel starvation, and 2) distributor/cap/wires.
