So today I had to put the 914 on hold to replace the upper manifold gasket on my '91 F-150. V8 5.8L by the way. The vaccum leak caused by the faulty gasket was really sucking a lot of power out of my engine. So I get it replaced, check, double-check, and triple-check to make sure I've got every wiring harness and vaccum line that I disconnected hooked back up, and that every bolt is torqued to spec, and I do. So I fire it up and... same sh*t- there's a vaccum leak somewhere. Granted the engine is idling smoother now than it was, but it's still rough.
Now, knowing my luck, the upper manifold gasket needing replaced was only hiding the fact that the lower manifold gasket has a break in it somewhere, but it's been my experience that these gaskets rarely break or leak unless they were either installed improperly or the mounting bolts have come loose. Of course this is something I can't really check without once again removing the upper intake, and at this point in my day it's a moot point since I have to be to work in less than 2 hours.
So can anyone give me an idea of what else I might check? Like I said, I made sure all vaccum lines were hooked back up, so the only thing I can figure is that maybe I was getting a little too rough unhooking/hooking the lines and cracked and/or broke one of the plastic lines. I suppose I'll double check that while I'm awaiting a response.
Here's the rundown:
-Before replacing the gasket, the engine ran rough at idle (about 400-500 RPM) but smoothed out once speeding up and the RPM's rose to 700-900 with no problems during acceleration.
-After replacing the gasket, the engine still runs rough at idle, but now I'm noticing the leak is worse when accelerating, but still smooths out once the engine reaches 700-900 RPM.
Thanks!
