I just rebuilt my front calipers, including new pads. Have yet to re-fill/bleed.
On one side, the hub/rotor spins freely with only slight rubbing of the pads. Feels "normal" as compared to other cars I've worked on.
On the opposite side, the hub/rotor does not spin freely. It spins only with some effort.
Both rotors measure the same thickness (a little under 10mm).
Will this issue fix itself once I re-fill & bleed or is something wrong?
