QUOTE(Bruce Allert @ Jan 20 2004, 08:39 PM)
Dan, slide the seat almost as far forward as it will go. On the side of the seat that doesn't have the handle for moving the seat back & forth (under the track) is a blade that needs to be pushed up. If the seat is too far forward it will be hard to push it up. Once you get it up & hold it the seat will slide out. Get a good light & take a look at it. It kinda blends in with the rest of the track.
what he said.
but you need no stinking screwdriver.
the drivers seat should be easy with the cast on your right hand, all you have to do is push the seat forward with it.
now, pull up the handle and move the seat as far forward as it goes. then slide it back just a bit (1cm or so).
then, take your left hand and find the rail closest to the door.
you can feel the metal "blade" which you can bend up easy with a finger or two.
then, push the seat forward, it'll slide right out.
while you have it out, now is a good time to check for rust on the floor board. do the crunch test, press on the tar and if you hear it crunching, you have rust.
also, put some grease on the seat rails before you put the seat back on ...
Andy
