Ericv1
May 15 2008, 03:08 PM
I read a thread recentley about dipping and cleaning carbs with berrymans' carb cleaner. One member said to remove all of the brass and then dip. Is it because brass is soft and could be eaten away by the cleaner? PLease let me know. Thanks, Eric
ericread
May 15 2008, 03:13 PM
I feel like I'm in an echo chamber... (Thjis thread was posted twice)
Since the duplicate post has been removed, my response makes no sense whatsoever.
Soooooooooooooooooooooo, Never mind.
So.Cal.914
May 15 2008, 03:20 PM
All I can tell you is this. I googled berryman's carb cleaner+brass
pieces+Problems. I read an article about getting a motorcycle ready
after winter storage. They used Berrymans on the carbs without
removing any brass.
burton73
May 15 2008, 06:31 PM
I just looked at my Berrymans cans I and its says “use on all metal and alloys”. It cleaned my brass right up on my carbs. Plus the small parts in the dip tray they give you.
Bob
Ericv1
May 15 2008, 06:46 PM
QUOTE(So.Cal.914 @ May 15 2008, 05:20 PM)
removing any brass.
Thanks, Bob, I found the thread on 914club. But there's no specifics as to why the person said to remove the brass parts. Eric
r_towle
May 15 2008, 08:12 PM
If you dont remove the brass you arent doing a decent job.
Brass includes, F-tubes, idle jets, idle screw, air screw, etc etc etc.
The lower air bypass screws have a rubber o-ring that wont last any decent cleaner.
The gaskets will be junk
The floats wont like it, nor will the rubber on the needle valve.
Take two carbs...leave on if front of you totally assembled.
Take the other one apart, and dip the body of the carb, with nothing in it.
Otherwise you will loosen alot of crap and it will have no place to go but to clog up jets...
Do it right, or dont bother.
Rich
Gint
May 15 2008, 09:59 PM
You can put the brass in the Berryman's. It won't hurt it. I strip my carbs completely apart and use the little collander looking bucket for all of the individual small pieces including the brass. No issues ever with brass or other metals in over 25 years of using Berryman's.
craig downs
May 16 2008, 12:03 AM
I clean everything with it accept rubber seals and gaskets. Just be careful with it use gloves and be careful about splashing any on you. The sink will follow you around for a couple of days.
Ericv1
May 31 2008, 07:59 PM
Here's the carb before hours of cleaning and replacing the gaskets.
Ericv1
May 31 2008, 08:00 PM
My bad.. This was the after shot. I'm still learning how to post pics. Eric
r_towle
May 31 2008, 08:01 PM
I was gonna say...damn you are a perfectionist if that is before....
Rich
Ericv1
May 31 2008, 08:02 PM
Here's the before shot on the right side. I think it turned out pretty well.
burton73
Jun 1 2008, 12:03 AM
I removed the circled arrears. There was tar like old gas in the back of the accelerator pump. You have to get all of that stuff out. I put the finished crab in my solvent sink to see that the solvent was flowing all over. I have only done one so far and I am still worried that it will not be perfect. Crabs are an art. My shafts where stuck after sitting for 18 years and I needed to prove that my crabs and shafts where still good with out slop.
Bob
Ericv1
Jun 1 2008, 05:56 AM
QUOTE(burton73 @ Jun 1 2008, 02:03 AM)
Bob
Click to view attachmentI'm pretty sure these carbs had been gone through before. The engine was sitting for 4 years. However, when I dismanteled the carbs, there was no sludge or tar buildup. The shafts stuck a little bit after soaking for 5 days. A little penetrating oil freed them right up. Its' now time to start number two. Eric
IronHillRestorations
Jun 1 2008, 10:06 AM
JIC you didn't know, never ever ever poke wire in the air or fuel passages to clean them out.
Your carb looks great!
