QUOTE(Cap'n Krusty @ May 16 2008, 04:27 PM)
Since that engine DOESN'T HAVE a pan gasket, there are replies here that may be erroneous. Toyota, like GM, uses a Loctite product to seal the pan. It "could" fail, but I have my doubts if it was properly applied. Damn stuff is a PITA to remove. In fact, it's hard enough just to get the pan off. The Cap'n
That was 1978, So I used a sealer instead? Woah, erroneous. I remember it was a pain in the ass.
Edit: Yup, went and did some reading. Cap'n right (still don't remember) no
gasket on the pan. But what most of them were fixing was the front crank seal,
Most said it was an easy fix. Google Toyota+R22+fix oil pan leak, thats where I
found the Write ups on the pan and valve cover, front and rear seal
