Ok guys, I have an issue with the front drivers side turn signal. this happened a little while back.
1. the passenger one works fine
2.the Emergency flashers work fine they light up on the drivers side also.
3. have checked all the wiring to the turnsignal housing for proper placement
4. getting continuity with the bulb. and the bulb installed in the housing
then I thought it might be the relay.. it doesn't seem like it since the Emergency flashers work.. (or is it a different relay?) and the Right side works fine when i do the safety light where you flip the turn signal switch without the ignition on..it doesn't light up. of course if the front ones not working then the back isnt going either.. I've cleaned the contacts for both the front and back.. but no luck.. is there another spot where the turnsignal's are grounded on each side?
Anybody have any ideas? possibly the turnsignal switch?
ohh and its a 72
Thanks in advance,
