JOE M
May 20 2008, 08:37 AM
I got my rebuild kit a few days ago and installed all the parts. I found that the kits came with the later model pump diaphram so I have to use my old pumps until I get the replacements. After about 30 minutes of tuning , the carbs seem to be working well. I still have some fine tuning. Prior to this I had a friend recheck my timing and valve adjsutmnts. All is well and compression is finally even all around about 110psi (still a little low).
So yesterday I started the car and began making some adjustments to the carbs. I turned the car aff and was checking for leaks and I heard a noise like fluid draining. I watched as gas filled each barrell. I am not sure why but after I stop the engine all the gas in the bowl leaks into the barrells (how is thisn possible??). This is happening on both carbs. Any thoughts??????
Thanks in advance.
Forgot to say they are weber idf40
jmill
May 20 2008, 10:25 AM
Where is the fuel coming out? I can't be sure but, from you explaination, I'd say look at your accelerator pumps. It sounds like your draining down the float bowl through your accelerator pumps. Check to make sure you installed everything correctly. Is there little rubber check valves in your pumps? I don't know the IDF that well.
If this is the problem you'll be much leaner after the fix. Make sure your jetted properly.
I've seen fuel puke out of carbs when the float level is set incorrectly or the needle doesn't seat well. This only happens when the fuel pump is running though.
JOE M
May 20 2008, 12:09 PM
QUOTE(jmill @ May 20 2008, 08:25 AM)
It could be the pumps. The weird thing is that when the car is running all seems well. The car runs well and when I give it more gas it responds well. As soon as I kill the engine I can hear a hiss sound and I can see the gas filling above the throttle plate. I will take them apart again and verify how much fuel is actually filling the carb.I noticed this because I saw some smoke coming out of the barrells after I killed the engine.It kind of looks like a smog machine. It would be cool for halloween but I want to drive between now and than..LOL.
SLITS
May 20 2008, 12:36 PM
Ok, wild stab here .... if you do not have bakelite insulators between the manifolds and head you could feasilby get the carbatooters hot enough to volatize (boil) the fuel in the bowls and push it out the ports filling the venturis. Just a thought.
jmill
May 20 2008, 12:44 PM
That would do it slits. The bowl would get pressurized and puke fuel out the mains. Thats why I asked him where it was coming from. Knowing the source would make finding the problem a lot easier.
VaccaRabite
May 20 2008, 12:57 PM
I just rebuilt mine as well, and put on the pheneolic spacers (how ever that is spelled.) Hopefully I won't have the same problem.
Sounds like it could be an explosive situation.
Zach
purple
May 20 2008, 01:12 PM
its funny, i had the phenolic spacers on my old single weber and it ran great. I switch to dual webers the thin gaskets (i broke the phenolics getting them off for a tin fix) and it runs like RUBBISH!
the plastic will help my carbatooters, you say? very fine! I have ordered my new carbatooter gaskets from pelicantooter parts. I hear they give you a better seal than the thin shit anyway. Any thoughts on that?
jmill
May 20 2008, 01:27 PM
Fuel needs to reach about 475 F before it flashes. I doubt the carb would get that hot. But as fuel temp increases so does its vapor pressure. Fuel would be pushed out of the jets instead of vacuum dragged if the bowl gets pressurized. It would make your carbs impossible to tune. Every carb I've dealt with has a vent on the bowl to prevent this. You might want to see if the vents are plugged.
ericread
May 20 2008, 01:31 PM
Carbatooters!
PelicanTooter Parts
I'm just glad I stayed with my FI. No carbatooters for me. No siree!
JOE M
May 20 2008, 01:40 PM
QUOTE(ericread @ May 20 2008, 11:31 AM)
Carbatooters!
PelicanTooter Parts
I must be missing the joke --carbatooter and pelicantooter???? I need a good laugh fill me in.
purple
QUOTE(ericread @ May 20 2008, 02:31 PM)
Carbatooters!
PelicanTooter Parts
the previous owner made that choice for me.
it had a weber carbatooter on there, a single progressive with a WATER CHOKE, however that F that works.
My carbs are pretty painful to tune, but they are brand new. I think i need to set the float level and go down a size in idle jets. they are running wayyy too rich. the idle screws are almost all the way in, too.
ericread
May 20 2008, 01:51 PM
QUOTE(JOE M @ May 20 2008, 12:40 PM)
Carbatooters!
PelicanTooter Parts
Sorry. I guess I have a stange sense of humor
Come on now, "carbatooter" is funny stuff!!!
Just saying "Carbatooter" out loud makes me laugh!!! In my earlier days I spent endless hours rebuilding carbs, and identifying them as "carbatooters" cracks me up!!!
.... it may be apparent that I don't get out much
jmill
May 20 2008, 01:52 PM
I love carbs myself. A simple jet change is much easier then changing injectors and remapping fuel curves. I does however take some tuning and tweaking. I've got a great book on the IDF at the house. If you still scratching your head tonight I'll help you out.
SLITS
May 20 2008, 01:53 PM
Ach, meine Himmel ....
I should have added that this condition would feasilby occur on engine shutdown. No longer is luft flowing across the heads so the heat transfer to the manifolds/carbatooters would be greater.
May 20 2008, 01:58 PM
QUOTE(ericread @ May 20 2008, 11:51 AM)
DING DING DING - WE HAVE A WINNER !!!
as for the carbs, i ran my dual 44 IDF with the thick stock FI insulator gaskets between the intake manifolds and the heads.
it helped a lot to keep the heatsoak in check once the engine is turned off.
as long as the engine is running, the draft will cool the carbs and manifolds. once you turn the engine off, you'll get heatsoak from the heads up the intake manifolds and into the carbs.
if you only use the thin paper gaskets between the heads and manifolds, the manifolds will heat up much more and quicker ...
Andy
purple
May 20 2008, 02:04 PM
So, Herr Andy,
Which would you recommend for a gaskatooter? The thick or the thin?
Elliot Cannon
May 20 2008, 02:08 PM
I better check my own carbetaters. I fixed my ideal jet clogging problem. It seems the fuel falter in the carb itself was clogled and no fuel could get through to volitalize. Volitazation is important!! That what cabetaters are for.
May 20 2008, 02:15 PM
QUOTE(purple @ May 20 2008, 12:04 PM)
So, Herr Andy,
the thick FI insulator gaskets ...
they come with a thick hard plastic core and two thin paper gaskets glued on each side. i put a thin layer of gasoline resistant RTV (GASP!!!) on each side and made sure the mating surface on the heads and intake manifolds was level and clean ...
Andy
sww914
May 20 2008, 02:17 PM
I have a pear of Webbberrz with the thickening pheoholic spasters and my many folds stay plenty cool. Running without the phenoholic spasters seems like a bad idea. Elliot, make sure that your falter holders are in there good, one of mine liberated it's self on the track and my car was crisping before I knew it. I put a bead of RTV around the head now just to make sure that they can't come loose anymore.
purple
May 20 2008, 02:18 PM
All this talk about carb teats and toots makes me want to go to the bathroom.
Elliot Cannon
May 20 2008, 02:33 PM
QUOTE(sww914 @ May 20 2008, 01:17 PM)
Hi! "I'm Elliot... and I'm a phenoholic." (I've been going to phenoholic meetings for years.)
Cap'n Krusty
May 20 2008, 02:39 PM
QUOTE(Elliot Cannon @ May 20 2008, 01:33 PM)
Perzakly what is "phondolick" anyway? The Cap'n
sww914
May 20 2008, 02:43 PM
The first step to recovering (upholstery?) is admitting that you have a problem to Huston.
purple
May 20 2008, 02:50 PM
Reporting can be done to me... I'm in the planet Houston
markb
May 20 2008, 03:33 PM
QUOTE(sww914 @ May 20 2008, 12:43 PM)
Dontcha hafta cover before yew can recover?
ericread
May 20 2008, 03:42 PM
This thread is killin me!!!
Elliot Cannon
May 20 2008, 06:33 PM
QUOTE(Cap'n Krusty @ May 20 2008, 01:39 PM)
Phondolick is a town in Woskonson. (Hell, any grade school kid knows that).
purple
May 20 2008, 06:36 PM
we're a bunch of goofy MFers
JOE M
May 21 2008, 05:26 AM
I think I found the problem. It appears that the pump spill screw had a rubber gasket on it. There should be no gasket on this screw. This is the screw that sits on the bottom of the bowl. It seems like it is some sort of check valve because there is a bearing of some sort in it. I had no gas left in the car and I also had no time to work on it last night.
