I have been removing the paint on doors and hood and engine lid outside of my shop with air tools with 3M pads. Now that I have the rest of the car on a rotisserie and I need to do the trunks and panels inside my clean shop I find it too dusty to use the 3M pads pad for the big job. Regular paint remover is too strong of a smell and burns your shin if you flick any on your self when you are working with it. The solvent gets you much too stoned.
The good: This water-based stuff is does not burn. It does not need to be neutralized it does not dry out. It has no smell at all. I use latex low cost gloves and change them all the time. The paint brush does not dry out.
The bad: It takes 30-48 hours to work well. You put a thick layer on and go back later and brush it around some more. I then just used a metal scraper blade and the old paint just came up. Even Por 15 that was put on my flares by the welder came off (in 8 hours) I cleaned up with Acetone and a rag in the end.
Cost was $53. Per gallon. On the web 5 gallons are less. Sherwin Williams home paints stores sells it. When I called the factory they said it will remove paint from Fiberglass without eating the fiberglass.
Bob
Click to view attachmentClick to view attachment
