QUOTE(Dr. Roger @ May 25 2008, 06:25 PM)
I think my '74 has single bleeders.
Was there a particular year for double bleeders?
Thanks,
Roger
My '76 has both. I think that technically, the lower one is for flushing, the upper one is for bleeding. If you think about it, with only an upper one, the old fluid will stay in the cylinder and never come out when you bleed. So you open the lower one to flush (drain) the old fluid, then finish it off by bleeding from the top one.
