Engines is out and on the stand and I'm replacing seals to chase a leak. *I think* the leak was coming from the taco plate. But, should I pull the pushrod tubes and seals while its out? I don't think it was leaking from the tubes but can't be 100% sure. Is it just as difficult to get them installed properly on the stand as it is in the car? I've done the search and I it appears often the leaks are worse after the first attempt at changing the seals. Not sure if this is because it's hard to be successful with the engine in the car.
Cheap insurance or don't F with it if it looks okay? Opinions please, never done it before so don't know what I'm in for...
Kev
