Pat Garvey
May 26 2008, 08:11 PM
Why, at least into 1976 (maybe later) did Porsche utilize horizontally placed cooling fans on some models? Was it wieght savings? Was it better cooling?. And, how did the fibergalss/composite fans hold up long term?
Just want to know.
Pat
r_towle
May 26 2008, 08:30 PM
I think that the horizontal ones that I have seen were only on race cars.
I would think that space savings along with better control of the air would be the rational.
Our system was probably alot simpler to build, and certainly simpler to maintain.
A vertical fan on an 8 or 12 cylinder would deliver super hot air to the rear cylinders, so two horizontals deliver a better and colder shot of fresh air.
Rich
Dave_Darling
May 26 2008, 09:32 PM
Better cooling, but it ate more HP to run.
--DD
zymurgist
May 27 2008, 05:39 AM
If I remember correctly, they used an aircraft quality gearbox ($$$) to translate the axis of rotation from horizontal to vertical. I guess the Chevy Corvair double-bent-belt method wasn't considered reliable at the speeds those engines were turning.
Jake Raby
May 27 2008, 10:57 AM
The horizontal fans were driven via bevel hears directly off the crank. The method they were driven with didn't draw more HP, it just cost 4x more than a belt driven arrangement.
