dbgriffith75
May 28 2008, 11:26 AM
I've already removed the old lines so as to get them out of the way when I do the paint, and what I've done to aid in feeding the new lines is I fed light gauge wire through the old lines before removing them, then just tied bolts to each end of the wire to prevent them from falling out. It may not be the best way, but it's at least a guide.
Anyway, I'd like to know what's reccomended to do replace them with. As you can imagine the old plastic lines are frail and brittle, and I've already broken them more than once. I'd like to replace them with steel lines. But would aluminum/copper/brass be better?
plymouth37
May 28 2008, 11:36 AM
I would go with stainless, Tangerine Racing (CFR) makes a nice kit. Here is the
LINK
VaccaRabite
May 28 2008, 11:37 AM
CFR stainless steel fuel lines are the way to go, if you want pre-bent.
Make your own from stainless brake line if you want to save money and DIY.
Zach
ericread
May 28 2008, 11:41 AM
Take a look at Tangerine Racing. The basic set is $85.00. Takes an hour or so to install and they are really high quality. As a representative CSOB, I say it's the only way to go.
Eric
BTW: Tangerine Racing = CFR; Same dude.
dbgriffith75
May 28 2008, 01:52 PM
Right on! Consider it DONE!
